Sager forks
For what it's worth... I count at least three different forks that Sager produced...
1. An attachment to hook up to an existing rigid fork for both bicycles and motorcycle. This fork had a brace that attached to the outside of the rigid legs. There is a photo on p. 104 of "At the Creation". I personally have never seen pix of this on a motorcycle.
2. The Sager fork that was used on the bike Walter is sitting on in "early" 1907. The only reason I say early is that I have an 11x14 photo from the original glass negative. In the photo, you can see the flowers in the grass in bloom. I guess the only thing that is for sure is that it is spring... I'll let others argue the year. This fork is not an attachment... the connection from the underside of the triple plates to the front leg is welded onto the bottom of the triple plates. It appears to be a poor and weak design. There is an orig paint bike in the midwest that I believe (now) to be a 1907 that has this fork. It's motor number is 1981. It has the smooth fenders, no exhaust cutout, and fuel filler in, gasp, the front with rounded edges! And it ain't no cob job near as I could tell.
3. The third style sager is the most commonly seen (like 2037 and 2042 have. When did they change to this style? 1907, mid 1907, or 1908. I am surmising it was mid-1907, but of course I am a little too young to actually have been there.
I understand Jurrassic's point that Harley may have developed their own fork sometime in 1908 and started using it as soon as it was done. 2177 has the later Sager fork, 2194 has the Harley fork. It is possible that the change was made in between these two bikes. The share the "less fins on cylinder" and the toolbox.
Fascinating stuff!
Fascinating stuff!
