Harley and the davidsons :-)(-:
  • Mickey Yak
    • Aug 2015
    • 10
    It will be interesting if they touch on the V Twin having come from a 7 cyl radial aircraft engine. It is said that is why they do not fire 180 apart,
      • 6044
      My favorite Hollywood car, or bike chase scenario is when the hero is being chased by a bad guy, and they're doing 100mph, and he's still shifting to higher gears. . . It does sound cool, however.
        • 8248
        Originally posted by DCoul View Post
        .... With all the effort that goes into these props, it seems like they could slap on a Linkert for a close up.
        Uh,.. What year is this supposed to be?
        PS: I'm the biggest stick-in-the-mud, because every 'citizen' that walks in my front door, mistakenly thinking its an antique shop, is going to ask me about it as soon as they see motorcycles.
        And I wont have viewed it. Went through that with "World's Fastest Indian", and then 'American P*ckers', and could only disappoint them with my ignorance.
        I only get free antenna TV.
          • 4791
          You are aware that V-Twins existed BEFORE radial aircraft engines right? And the firing order has to do with the degree difference between cylinders. In order to fire 180 apart the engine has to be 180 degree different on the crank throws, which no vee is....
            The show blew thanks to Discover CH greed. 15 minutes of commercials for 5 minutes of programing. Maybe some of you guys have the patience for it? But me, I just turn it off. I already paid once to see the f--king show. Bob L
            • Mickey Yak
              • Aug 2015
              • 10
              This came out of Wikipedia.
              In 1903–1904 Jacob Ellehammer used his experience constructing motorcycles to build the world's first air-cooled radial engine, a three-cylinder engine which he used as the basis for a more powerful five-cylinder model in 1907. This was installed in his triplane and made a number of short free-flight hops.[4]
              My thoughts are
              An engine can Fire 180 degrees out. The exhaust and compression stroke would have to be opposed. If HD did not use 2 cylinders out of an 7 cylinder aircraft engine then please give me your theory on why they timed it the way they did?
                • 4791
                You answered your own question. A 45 degree twin CANNOT have opposed cylinder timing due to simple design restrictions and the fact that a 4 stroke engine needs 360 degrees to complete on cycle PER cylinder, consequently a 45 degree twin fires at 360 minus 45 degrees and then again at 360 plus 45 degrees, or at 315 and then at 405, which gives it the distinctive exhaust note. Keep in mind the common crankpin, so the cylinders DO NOT have any other way to function within that 360 degree parameter. 180 degree opposed twins all have separate crankpins opposed to each other at 180 degrees, such as many parallel twins and all flat twins.
                And this isn't "my theory", it is known documented engineering practice.
                  • 6044
                  You're going to lose this argument Mickey
                  • Mickey Yak
                    • Aug 2015
                    • 10
                    Not trying to win an argument. It more about the myth.
                      • 6044
                      Glenn Curtiss, of aviation fame is credited with building the first V-twin motorcycle in 1903. He was certainly the most progressive motorcycle builder of that time, and quickly transitioned into motorized aviation.
                      • AFJ
                        • 465
                        G. Daimler patented the first V-twin engine and used it in his second car. US patent number was 418112 issued Dec. 24, 1889. It had a angle of about 15 degrees as I recall and Panhard and Levassor built and used this design.
                        AFJ
                        • Steve Swan
                          Possessed by Motorcycles
                          • Aug 2013
                          • 1589
                          #27
                          Did the Davidson's really fight, drink and parlay in saloons as much as the series portrayed ?
                          Did Walter Jr experience an adolescent rebellion, stealing parts and tools from the factory so he could fit in with a pre-1%er club that Walter Sr sponsored the 1st knucklehead in an 'outlaw' off road race ?
                          Steve Swan
                          27JD 11090 Restored
                          27JD 13514 aka "Frank"
                            • 4791
                            #28
                            Yes, they lived EXACTLY as portrayed, the most correct historical offering ever. No one ever got it right before. Willy G even started SOA!
                            • motorhead1
                              • Dec 2006
                              • 171
                              #29
                              Now that's funny! I don't care what you say. Good one Robby!
                              Ride 'em. Don't hide 'em.
                              Dan #6938 FUBO
                              • kiwi tibbs
                                • Sep 2015
                                • 22
                                #30
                                Originally posted by Steve Slocombe View Post
                                Dear Chris, I guess it will be like a visit to the Harley Museum and meant for family entertainment rather than hard core rivet counters like us. Harley-Davidson must surely have been consulted, so I'd expect something relentlessly upbeat. I still like the trailers though, and will be watching the whole thing as soon as I can.
                                Hi Steve,
                                I've sent you a private message.
                                Cheers
                                Tony
