1912 H-D 49" Belt Drive Twin Model X-8-D
  • Slojo
    Evil Twin Doctor
    • Oct 2007
    • 880
    When comparing a twin cylinder belt tensioning quadrant gear to a singles quadrant gear there is a difference. The difference is the location of the quadrant gear teeth rotated CCW approximately two teeth away from the arm carrying the idler pulley . This change is due to the pivot point location of each bikes quadrant gear hand lever. I have a unit for a single cylinder model. It would appear that a trip to the wire EDM shop is necessary to remove the gear teeth and then to the welder to reattach it where it needs to be for the twin cylinder application.
    I also had to shorten the link bar between the clutch lever and the throw out bearing about one and a half inches to convert the single cylinder part to twin status.
    Next conversion is to determine the pedal crank modification required to extend the pedal sprocket about 7/16 further away from the centerline of the bike to align the chain with the rear wheel sprocket.
    Does anyone have a twin cylinder model belt tensioning quadrant or left crank arm?
    Joe
    • motosmith
      • Feb 2012
      • 32
      I build 1912 tanks and tool boxes and have nice originals. Get ahold of me and I'll get you the measurement you need.
      Jethro Smith
      antiquemotosmith.com
      antiquemotosmith@gmail.com
      all early seats & Gas tanks
      • Tommo
        • Sep 2001
        • 1320
        Slojo
        I've got a postcard that shows an early HD twin without guard valances.
        I've attached both a greyscale and a colour copy.
        If you want better copies I'll laser photocopy it and post them to you.
        Lets know your thoughts.
        Peter Thomson, a.k.a. Tommo
        A.M.C.A. # 2777
        • Slojo
          Evil Twin Doctor
          • Oct 2007
          • 880
          Tommo
          Good to see your still on the job. The photos that you posted are of a 1911 double model 7-D not a 1912 twin model X-8-D , still very good photos. I do have a 1911 double so any photos of that bike are interesting to me.
          By the way, a factory brochure for 1912 displays two 1912 singles on the cover without the valances on the front fenders.
          joe
            • Feb 2003
            • 5353
            Cory Othen
            Membership#10953
            • Slojo
              Evil Twin Doctor
              • Oct 2007
              • 880
              Originally posted by c.o. View Post
              Does anyone know who the owner of this bike is?
              joe
              • silentgreyfello
                • Nov 2006
                • 861
                Here are pics of JP's 12 twin chain drive. Unfortunately, I didn't take more than these when I was at the museum in Anamosa as I was in a hurry. If you call them, they may take some for you. Probably not what you want, because it's chain drive. I have some pics of a belt drive somewhere...
                  • Feb 2003
                  • 5353
                  Nice!!!!
                  Cory Othen
                  Membership#10953
