WTB Panhead front cylinder
  • WTB Panhead front cylinder
    I'm looking for a 53-62 front cylinder 30 thou over or less. I have two rears, one at 10 over and one at 30 over, so as close to standard bore the better, so I can use the 10 over.
    I have purchased brand new engines from H-D that had different bores on them. I had one that had one .010 and the other was .040. A brand new Shovelhead engine.
      I'd hate like hell to have mismatched cylinders. I'd rather buy one set of pistons than two.
        H-D always sold pistons individually. If you needed a a pair you bought two! And as Chris said, the factory did it all the time. My UL has had a standard and a .020 cylinder for 30 years. Runs just fine! But I'll look and see what I may have Dewey!
        Robbie
          One of the smoothest running 1950 Pans that I ever rode belonged to an old guy by me. When we took it down to rebuild the motor it was .040" over 61 (3 5/16 = .040) on the front cylinder and .070" over 74 (3 7/16" = .070) on the rear. That is a difference of .165" and it was smooth as silk. I never bore a cylinder more than what it needs to clean up. More cylinders were used up in a machine shop than ever got used up on the road.
          Jerry
            I think Kick Start sells pistons individually, rings are in sets.
            Bob Rice #6738
              Jerry
              I'm not discounting running different sized cylinders if it turns out that way, and BigLakeBob informs me that pistons are available individually, so that's a help. I wouldn't take a cylinder out just to match it's mate, but I have two or three years before this pan gets on the road so I figure I'd start by looking for something close to what I already have.
                cdndewey
                By all means I try to stay with the same bore but it is nowhere near my first requirement. As long as you have time I too would try to match bores. Jerry
