I'm looking for a 53-62 front cylinder 30 thou over or less. I have two rears, one at 10 over and one at 30 over, so as close to standard bore the better, so I can use the 10 over.
WTB Panhead front cylinder
I have purchased brand new engines from H-D that had different bores on them. I had one that had one .010 and the other was .040. A brand new Shovelhead engine.Be sure to visit;
I'd hate like hell to have mismatched cylinders. I'd rather buy one set of pistons than two.Originally posted by Chris Haynes View PostI have purchased brand new engines from H-D that had different bores on them. I had one that had one .010 and the other was .040. A brand new Shovelhead engine.
H-D always sold pistons individually. If you needed a a pair you bought two! And as Chris said, the factory did it all the time. My UL has had a standard and a .020 cylinder for 30 years. Runs just fine! But I'll look and see what I may have Dewey!
RobbieRobbie Knight Amca #2736
One of the smoothest running 1950 Pans that I ever rode belonged to an old guy by me. When we took it down to rebuild the motor it was .040" over 61 (3 5/16 = .040) on the front cylinder and .070" over 74 (3 7/16" = .070) on the rear. That is a difference of .165" and it was smooth as silk. I never bore a cylinder more than what it needs to clean up. More cylinders were used up in a machine shop than ever got used up on the road.
Jerry
I'm not discounting running different sized cylinders if it turns out that way, and BigLakeBob informs me that pistons are available individually, so that's a help. I wouldn't take a cylinder out just to match it's mate, but I have two or three years before this pan gets on the road so I figure I'd start by looking for something close to what I already have.Originally posted by Jerry Wieland View PostOne of the smoothest running 1950 Pans that I ever rode belonged to an old guy by me. When we took it down to rebuild the motor it was .040" over 61 (3 5/16 = .040) on the front cylinder and .070" over 74 (3 7/16" = .070) on the rear. That is a difference of .165" and it was smooth as silk. I never bore a cylinder more than what it needs to clean up. More cylinders were used up in a machine shop than ever got used up on the road.
Jerry
cdndewey
By all means I try to stay with the same bore but it is nowhere near my first requirement. As long as you have time I too would try to match bores. Jerry
