Results 1 to 10 of 14
Thread: 48 Pan engine mounting problem
    Default 48 Pan engine mounting problem
    Hi Guys
    On reinstalling there is no clearance between the rear head and the frame, which I hadn't noticed when removing the engine. I believe this should be 3/16" to 1/4"? Is there a best practice for this? If not, I would be tempted to reduce the height of the forward mounts, and/or install shims at the rear?
    Greg
    Nov 2010
    283
    Greg; It looks like you have the thick rocker arm cover gasket installed. I would use the thin ones which would solve your clearance problem.CIMG1727.JPGCIMG1728.JPGCIMG1730.JPG
    Craig
    Hi Craig
    Not that simple, I'm afraid, It's the head that is also against the frame, It appears I can cure this with 1/8" shim between the rear engine support and engine. Whilst ideally I'd fabricate a full length bracket, could I get away with a couple of 1/8" washers???
    Greg
    Ohio
    744
    If the motor sits flat between the front and rear mounts you can't just add to one without making the other uneven. I think washers are not a good approach. If things are already painted and finished you are kinda locked in with where you are at. I have removed some of the head in this area to help with the problem. Using a dremel, radius the head to clear the down tube, if that is the problem.
    Bob Rice #6738
    3,115
    I hate stupid cell phone pictures not oriented correctly. Therefor I have zero opinion on a fix....
    Thanks for all your comments - problem sorted
    Ohio
    744
    Hopefully you will share your fix or what caused the problem.
    Bob Rice #6738
    Menomonie, WI
    1,373
    Usually this type of problem is reserved for Knucklhead frames. If you mounts are all in good condition on both engine and frame it means your frame has settled at the seat post which is fairly common on frames with a rougher life. I just put them in my fixture and shove the top of the frame back until it holds and engine fits. Just did this to a Knucklehead frame last week.
    Jerry
    Quote Originally Posted by harleygreg View Post
    Hi Guys
    Greg
    May 2009
    175
    Jerry, Do you have a photo of this process?
    5,586
    Remove the paint from the motor mount surfaces.
