48 Pan engine mounting problem
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys
    On reinstalling there is no clearance between the rear head and the frame, which I hadn't noticed when removing the engine. I believe this should be 3/16" to 1/4"? Is there a best practice for this? If not, I would be tempted to reduce the height of the forward mounts, and/or install shims at the rear?
    Greg
  • 41craig
    • Nov 2010
    • 410
    Greg; It looks like you have the thick rocker arm cover gasket installed. I would use the thin ones which would solve your clearance problem.CIMG1727.JPGCIMG1728.JPGCIMG1730.JPG
    Craig
    • harleygreg
      • Oct 2018
      • 215
      Hi Craig
      Not that simple, I'm afraid, It's the head that is also against the frame, It appears I can cure this with 1/8" shim between the rear engine support and engine. Whilst ideally I'd fabricate a full length bracket, could I get away with a couple of 1/8" washers???
      Greg
      • BigLakeBob
        • 2767
        If the motor sits flat between the front and rear mounts you can't just add to one without making the other uneven. I think washers are not a good approach. If things are already painted and finished you are kinda locked in with where you are at. I have removed some of the head in this area to help with the problem. Using a dremel, radius the head to clear the down tube, if that is the problem.
        Bob Rice #6738
          • 4787
          I hate stupid cell phone pictures not oriented correctly. Therefor I have zero opinion on a fix....
          • harleygreg
            • Oct 2018
            • 215
            Thanks for all your comments - problem sorted
            • BigLakeBob
              • 2767
              Hopefully you will share your fix or what caused the problem.
              Bob Rice #6738
                • 2024
                Usually this type of problem is reserved for Knucklhead frames. If you mounts are all in good condition on both engine and frame it means your frame has settled at the seat post which is fairly common on frames with a rougher life. I just put them in my fixture and shove the top of the frame back until it holds and engine fits. Just did this to a Knucklehead frame last week.
                Jerry
                Originally posted by harleygreg View Post
                Hi Guys
                Greg
                [ATTACH=CONFIG]27684[/ATTACH] [ATTACH=CONFIG]27686[/ATTACH] [ATTACH=CONFIG]27688[/ATTACH] [ATTACH=CONFIG]27685[/ATTACH]
                • larry
                  • May 2009
                  • 247
                  Jerry, Do you have a photo of this process?
                    • 5954
                    Remove the paint from the motor mount surfaces.
                    • gitguy
                      Middle-of-the-road Member
                      • Nov 2009
                      • 254
                      Try right click and "open in new tab". When I do that they are oriented correctly.
                        • 2024
                        I will look and see. I have photographed it but not recently.
                        • larry
                          • May 2009
                          • 247
                          Thank you much.
                          • 41craig
                            • Nov 2010
                            • 410
                            Thanks for the tip gitguy! The sideway pictures is why I thought that the issue was the backbone clearance.
                            Craig
