Removing Spark Plugs on 1940 Sport Scout
  • kunzog
    AMCA #710
    • Dec 2001
    • 154
    I thought this would be easy but its not. After sitting for several years, I want to remove my plugs on the Sport Scout. Plugs are real close to tank. Is there a special tool needed or does tank have to be removed?
  • redfred84
    • May 2003
    • 399
    I used an antique Indian plug wrench on my own '40 SS when I had it. The wrench was a flat steel one, with a slight off-set. It had the 13/16 box end. Over the years, and especially with the racers; I've seen various alternatives to this issue. Some would change heads to the "angle plug" style, which located the plugs on a slant, allowing for better access. Some guys used lawn mower plugs that were much shorter. I had no problem once I employed this wrench though.
    RF.
    • charger49
      • Mar 2010
      • 23
      I use a old villiers plug spanner that we had laying around, seems to do the job ok.
      The rear plug is the closest and on our 41 you have to unscrew the top on the plug
      Before you can get the rear plug out.
      • kunzog
        AMCA #710
        • Dec 2001
        • 154
        Thanks Guys, I will have to start looking for a wrench that fits.
        • kunzog
          AMCA #710
          • Dec 2001
          • 154
          Well I figured it out. I used an Original Indian Wrench. I never thought to use that as it didnt look like anything special but thats what the Army maintenance manual shows. Thanks for the info.
            When in doubt, read the book!
            • Bill Huth
              • Jun 2009
              • 64
              I didn't have any flat or box wrenches that would go in there. So I took a flex socket, drove the pivot pin out, and just kept the socket part. I had to turn the OD down a bit on the socket to fit in between the plug and the fins. Then I just made a loop handle out of a piece of rod. Then I painted it my favorite color, Orchard Supply semi-flat black. Presto!IMG_1272.jpgIMG_1273.jpgIMG_1274.jpgIMG_1275.jpg
                • 1676
                ... broken fins, see what happens when you don't read the book?!?
                • Rod K
                  • May 2006
                  • 179
                  Hi Bill...Good job on the wrench. I always like to see home-made tools......Rod
