carburetor repair
  • carburetor repair
    looking for recommendations on who can repair schebler dlx 64, carburetor .thanks
    Tom Cotten
      Thanks Jerry,
      But eye surgery put me out of action.
      .....Cotten
        "looking for recommendations on who can repair schebler dlx 64, carburetor .thanks"
        What's it need?
        A picture would be helpful.
          Originally posted by sswaney View Post
          What's it need?
          Here's a rough general checklist, Scott!
          (Suggested flat-rate times to be adjusted as appropriate; No two are alike, even if the same model...)
          Disassembly and inspection 20 minutes
          Flame/Drill out frozen plug 10 ea
          Pull frozen nozzle 20
          Chemsoak / prep to conserve original finish 20
          Double-blast bowl; remove hammermarks and re-texture 30
          Prep as “Nickel” 15
          Blast Hardware and findings 10
          Hardware prep and detailing 30
          R&R throttle shaft bushings; line hone-fit 20
          Install choke shaft bushings; line hone-fit 30
          Dress to flat manifold flanges; Aircleaner, bowl decks _____ @ 5
          Lathe-cut 3-bolt flange 20
          Weld-out detent ball 10
          Restake 5
          Replace nozzle spigot 15
          Stake ‘n peen choke shaft 5
          Roll-peen choke shaft 10
          Hone damaged body bores 20
          Cut oversized throttle disc 30
          Swage-form venturi for fit 20
          Custom-cut venturi, material included 60
          Lathe-dress needle point ____ @ 5 ea
          Helicoils first 10
          additional 5 ea
          Re-cut HS needle seat 5
          Re-cut floatvalve seat; Burnish floatvalve needle to seat 15
          Cut Durable float 60
          Die-press floatlever pin bore and ream 5
          Scrub for assembly: Body; bowl each 5
          Reassemble and adjust body 30
          Reassembly bowl; adjust 30
          Every one is different, Folks; This DLX64 needed extra attention:
          PS: Finished conservation:
            "eye surgery put me out of action."
            Tom, Sorry to hear you are having problems with your vision.
            I have had a few "issues" there myself. Still have one solid peeper so fingers crossed,
              Thanks for the sympathy, Paul,..
              But they trashed both of mine; My career as a machinist is over.
              Need to liquidate.
              .... Cotten
                Tom, thanks for sharing the checklist.
                Much food for thought there.
                Having the skill required to perform the tasks is the problem.
                  ..Having the skill required to perform the tasks is the problem.
                  As well as an arsenal of machinery and tooling, Scott,.
                  Mine will likely be scrap.
