carburetor repair
  • cscott
    • Oct 2002
    • 452
    carburetor repair
    looking for recommendations on who can repair schebler dlx 64, carburetor .thanks
    • 2026
    Tom Cotten
      • 8248
      Thanks Jerry,
      But eye surgery put me out of action.
      .....Cotten
      • sswaney
        • 303
        "looking for recommendations on who can repair schebler dlx 64, carburetor .thanks"
        What's it need?
        A picture would be helpful.
          • 8248
          Originally posted by sswaney View Post
          What's it need?
          Here's a rough general checklist, Scott!
          (Suggested flat-rate times to be adjusted as appropriate; No two are alike, even if the same model...)
          Disassembly and inspection 20 minutes
          Flame/Drill out frozen plug 10 ea
          Pull frozen nozzle 20
          Chemsoak / prep to conserve original finish 20
          Double-blast bowl; remove hammermarks and re-texture 30
          Prep as “Nickel” 15
          Blast Hardware and findings 10
          Hardware prep and detailing 30
          R&R throttle shaft bushings; line hone-fit 20
          Install choke shaft bushings; line hone-fit 30
          Dress to flat manifold flanges; Aircleaner, bowl decks _____ @ 5
          Lathe-cut 3-bolt flange 20
          Weld-out detent ball 10
          Restake 5
          Replace nozzle spigot 15
          Stake ‘n peen choke shaft 5
          Roll-peen choke shaft 10
          Hone damaged body bores 20
          Cut oversized throttle disc 30
          Swage-form venturi for fit 20
          Custom-cut venturi, material included 60
          Lathe-dress needle point ____ @ 5 ea
          Helicoils first 10
          additional 5 ea
          Re-cut HS needle seat 5
          Re-cut floatvalve seat; Burnish floatvalve needle to seat 15
          Cut Durable float 60
          Die-press floatlever pin bore and ream 5
          Scrub for assembly: Body; bowl each 5
          Reassemble and adjust body 30
          Reassembly bowl; adjust 30
          Every one is different, Folks; This DLX64 needed extra attention:
          PS: Finished conservation:
          • PaulCDF
            • Aug 2019
            • 1438
            "eye surgery put me out of action."
            Tom, Sorry to hear you are having problems with your vision.
            I have had a few "issues" there myself. Still have one solid peeper so fingers crossed,
              • 8248
              Thanks for the sympathy, Paul,..
              But they trashed both of mine; My career as a machinist is over.
              Need to liquidate.
              .... Cotten
              • sswaney
                • 303
                Tom, thanks for sharing the checklist.
                Much food for thought there.
                Having the skill required to perform the tasks is the problem.
                  • 8248
                  ..Having the skill required to perform the tasks is the problem.
                  As well as an arsenal of machinery and tooling, Scott,.
                  Mine will likely be scrap.
