Paul,
I looked at Greer's for that since they show the late version. That u-bolt is 2.625 long so your spacing would be that or based on that center to center, right? They use a 5/16"-24 that is 1.625 diameter. I also have the plate because I thought it was standard since I saw it so often being sold that I just forgot to check if that changed. That's one of the hard-to-find parts, so I've never had one. Wouldn't a center measurement on the plate holes be more accurate than guessing about the u-bolt?
Here's the 1941 manual I pulled the photo from that had the plate. -JR
