101 transmission
  • cscott
    • Oct 2002
    • 451
    101 transmission
    hope someone can tell me how to identify a transmission case correct for a 29 101,45 motor thanks chris
  • RichO
    • Dec 2001
    • 903
    it matters to if it's a 45 or 37 inch motor,
    DrSprocket
    • PaulCDF
      • Aug 2019
      • 1425
      CS
      I know nothing about 101s
      Just a thought: Take a look at Harrys 101 build under Members Bike Builds "101 Scout... going to take a while"
      Check out: www.101scout.org
      (Don't know why print went bold Apparently I know nothing about word processing)
      • FLFD7
        • Feb 2021
        • 738
        Cscott,
        All 101 transmission cases are the same, 37 or 45.
        Here are some overall dimensions:
        The flange size is bigger then earlier Scouts because the clutch is bigger diameter.
        In the above photo you notice the 101 case has two notches on the OD of the flange, at about 1:00 o’clock the notch is for clearance for the generator drive, while at 5:00 o’clock there is a subtle notch, clearance for the brake cross over shaft.
        Joe
          Dear Chris, here's a stripped gearbox case from a 1928 101, fresh out of the dishwasher today.
          This gallery has 3 photos.
            • 965
            An easy tell from the similar chief is 6 flange holes instead of 7 for a chief trans.
            • cscott
              • Oct 2002
              • 451
              thanks very much, great info
