Scout frame repair
  • Nonmilagno
    • Oct 2016
    • 9
    Scout frame repair
    I have a ‘39 Scout subframe that needs a bit of welding done (loose chain rubbed on lower tube). It’s not very deep but I’d like to have it welded.
    I need to tell the welder what kind of steel the frame is. Anyone know?
    • 2026
    Call it chrome moly and weld it.
      • 8248
      Please warn your welder, Nonmilagno,...
      The frame members are brazed together.
      (Welding near a joint risks 'admixture'. And if its like the Chiefs I've repaired, everything but the tubing is cast iron.)
      Good luck!
        • 2026
        Good luck!
        Tom I think it is cast steel is it not? Jerry
          • 8248
          Once again, I only worked on a couple of Chiefs, Jerry,
          But on headstock cracks, center-stand lugs, and the like, I used piston rings for filler rod.
