Scout Balance Factor
  • canadianbiker099
    • Dec 2008
    • 14
    I am building a 1931 Scout engine. What balance factor works well with this engine? I am using the S&S balance tools.
  • PaulCDF
    • Aug 2019
    • 1438
    CB099
    Now; Please understand I am NOT an engine builder; hoping others will chime in.
    Best I can do is quote Professor Jim Mosher (60%)( hope that helps) and direct you to his site:
    Indian Performance Bottom Ends (performanceindian.com)
      • 8248
      Here we go again, Folks..
      (Please read all the way down to Herr Elvenkemper's experience.)
      http://virtualindian.org/Flywheeltheory4.htm
      We do not know what the original factor was for virtually any antique American motorcycle, and without back-calculating an unmolested assembly, we may never know.
      But odds are an early Scout wasn't sixty. Good thing they are so forgiving.
      PS: CB099!
      Have you inspected the fit of the tapers on the S&S arbor to the wheels?
      • canadianbiker099
        • Dec 2008
        • 14
        I made new ones to fit Indian tapers.
          • 8248
          Have you calculated your existing factor, CB099?
          • canadianbiker099
            • Dec 2008
            • 14
            No, it came to me apart with new T&O flywheels.
              • 8248
              Rather than picking a completely arbitrary number out of thin air, CB,..
              It might be best to get back to basics: "Hang" it with one piston assembly.
              • PaulCDF
                • Aug 2019
                • 1438
                You can't go wrong listening to Cotten.
                There is an interesting article on truing and balancing Indian Flywheels in the Club magazine archives: Sept/Oct 2015 issue pg 74-76
                "Lessons Learned More Secrets for Rebuilding Old Machines" by George Yarocki. I say interesting as even after reading it is still pretty much "Greek" to me.
                (Probably a re-read or two to three is in order).
                  • 8248
                  Originally posted by PaulCDF View Post
                  You can't go wrong listening to Cotten....
                  Sure you can, Paul.
                  Balancing is probably the most obfuscated topic of all, and I'm sure I've added to it somehow!
                  My back issues aren't in order; Did Mr. Yarocki put a number on 101s?
                  • PaulCDF
                    • Aug 2019
                    • 1438
                    Cotten;
                    On Balancing Mr. Yarocki mentions no specfic numbers.
                    He does use a set of rails of his own construction similar to the one you posted in #7 above.
                    He did state:
                    "Balancing is done using one piston, one wrist pin, two clips and one set of piston rings.
                    Drill holes equally in the outside of both flywheels at the heavy spot until the flywheels
                    will remain motionless in any spot."
                    BEFORE BALANCING He discusses Truing using a "Clamping method".
                    I was not able to link the article from the Archives to this post.
                    If you go to the AMCA home page
                    On the Right of the page is "Features"
                    Listed under features is AMCA Magazine Select this.
                    There is a Gray Box about 1/3 down the page on the Left (Archives AMCA Magazines) Select this.
                    You will need to log in if you have not already done so. NOTE AMCA Homepage log in is unique and
                    separate from Forum log in.
                    New Screen Appears.
                    On LEFT of page is Documents Folder with four options:
                    About(1)
                    Events(17)
                    Chapters(2)
                    Features(2)
                    Bottom Option "Features (2)" IS WHAT You want select "Features"
                    Now decades of past magazines appear: 2020s to 1960s.
                    Select 2010s
                    Mr Yarocki article appears
                    2015 Vol 54, Issue #5
                    (Sept/Oct) pg 74-76
                      • 8248
                      I appreciate your effort, Paul!
                      But after jumping through all the hoops twice, it still won't let me in: Refuses my email address for yet another password.
                      It would be easier to sort my magazines...
                      Getting into truing techniques would be endless.
                      ,,,,Cotten
                      • PaulCDF
                        • Aug 2019
                        • 1438
                        Almost two years ago (June 2020) I was having similar problems logging onto the AMCA Homepage.
                        I was trying to access the Library. Mike Love directed me to:
                        Carlene Kronau carlene@clubexpress.com
                        As The Homepage and Forum have different moderators. She was able to help me. Hopefully
                        she is still around.
                          • 8248
                          I appreciate that you emailed me the article text direct, Paul!
                          Mr. Yarocki's Brown and Sharpe ruler 'rails' (or 'knife-edges') never showed up in the dumpsters, but some 12" planer blades did, which I had ground in tandem to a 1/16" face. Very sensitive, but then so is round stock!
                          If I had to bet on a number out of thin air, CanadianBiker,...
                          I'd consider that your motormountings are much more like a Chief than a Sport Scout, so all other things considered, the factor should be similar as well.
                          That's my narrative, and I'm sticking to it.
                          • canadianbiker099
                            • Dec 2008
                            • 14
                            Thanks for the input guys. I think I will build a balancing tool like Indian recommended for this one.
                            • PaulCDF
                              • Aug 2019
                              • 1438
                              "build a balancing too"
                              CB099
                              I re-read Mr. Yarocki's article in the AMCA Sept/Oct 2015 issue. I am glad I did. Right at the start (probably while I was concentrating on my coffee) the author mentions some YouTube videos
                              with Mr. Yarocki that show balancing and his tool. Worth a look. Search YouTube for: "JAA1perin". Good Luck.
