Linkert Carb Question for 741
  • PaulCDF
    • Aug 2019
    • 1419
    I am piecing together a non-matching numbers Indian 741 (Seemed like a good idea at the time).
    Learning that parts for this model are harder to come by than those for Chiefs or so it seems to me.
    I do not have a M-741 carburetor.
    Rather than buying a 930 Amal spigot carb and adapting it to the Indian manifold.
    I do see an opportunity to buy a Junior Scout 30:50 Linkert M541
    From what I can find they both use the same manifold so there is that
    Both are 500cc
    From what I have found the 741 venturi is 3/4" and the Junior Scout 30:50 venturi is 1/16 smaller
    QUESTIONs:
    Would the M541 be sufficent "as is" for the 741?
    OR
    Will the M541 accept the larger 3/4" venturi?
    • 8231
    Originally posted by PaulCDF View Post
    ...Would the M541 be sufficent "as is" for the 741?
    OR
    Yes and yes, Paul,...
    But by my notes, an M541 crossed my benches with a miniscule 5/8" venturi,
    M741s usually had a 3/4", and M741-1 had 13/16" (102624).
    Unless you are a very large payload, or hope for maximum fuel mileage, I would suggest the 102624.
    • PaulCDF
      • Aug 2019
      • 1419
      Thanks Cotten!!!
      I figured you would know. You are the TRUE "Linkert Whisperer"
        • 8231
        Thanks Cotten!!!
        You're welcome, Paul!
        But I'm nothing special.
        I just 'read' carburetors, so others don't have to...
