Cast Iron Fin repair inside <------
  • ClassC Dan
    • Feb 2020
    • 17
    Hey All, since I'm new here Id like to share a repair I just did on a set of square base cylinders. These needed a bunch of fin repair, valve seats, and a sleeve, All work was done by me in my hobby shop.
    Broken exhaust spigot
    I used the cast iron bar, bored out on the lathe and sized to the correct OD
    Spigot welded on, I use lots of pre and post heat, and 99NI stick welding rod that I clean the flux off and TIG with it
    For the smaller repairs i was able to use some donor fins, but for this big one I used a good old fry pan, it was the right thickness
  • ClassC Dan
    • Feb 2020
    • 17
    continued
    welded up
    shaped
    Painted
    • pan620
      • Oct 2016
      • 223
      Thanks for the pictures, have ever used silicone bronze rod on cast iron?
      • ClassC Dan
        • Feb 2020
        • 17
        Hey, Pan620 I have not but I know a lot of guys do, I've just had pretty good success with NI99 so have stuck with it
          • 1667
          Dan, that looks like fun! Good on you to tackle the job, nice end result!
