My 1941 Sport Scout carb has a problem. When adjusting the low speed needle the ball bearing does not push hard enough against the knurled knob of the low speed needle to hold it from vibrating out of adjustment. When turning the needle I don't feel the clicking that I do on the high speed needle.
Should I replace the low speed needle lift lever? Or replace the low speed needle? Or is it possible to replace the spring and ball bearing and how?
