1926 Scout
  • Indiantim
    • Mar 2011
    • 61
    1926 Scout
    Hi Friends
    I have a 1926 Scout to rebuild, at some time water has been lying in the timing chest, all the gear teeth are too corroded to use. Any one holding these parts? or any pointers to a source.
    Many thanks
    Regards
    Tim
    '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
  • someozybloke
    • Oct 2013
    • 68
    Keep watching eBay and join the groups on Face Book. Send me a photo of how bad they are as mine were pretty bad but managed to recover them mostly. I picked up 1925 Oil pump from Norway recently off Facebook for less than the cost of parts I needed to replace. Send me a PM with the pictures of the cams.
    Mike
    Australia
    • Indiantim
      • Mar 2011
      • 61
      pictures of my corroded cams
      Regards
      Tim
      • gharper
        • Nov 2009
        • 528
        Kent Thompson in NH is your man for early Scout parts.
        • someozybloke
          • Oct 2013
          • 68
          Tim
          They definitely worse for wear, the cam wheels may may be salvageable but would be noisy.
          The oil pump drive (right) looks pretty rough as well and that will be hard to find as I have been chasing one for a while as well.
          Cam shaft is stepped and is not like a 101 or other scout cam shaft see attached picture.
          Will definitely need a new pinion gear (bottom left)
          • someozybloke
            • Oct 2013
            • 68
            Do you have a email address for Kent as I am still looking for a oil pump camshaft.
            • RichO
              • Dec 2001
              • 903
              Gene, I was on a road run in NH awhile back and they took us to Kent's shop. I don't think I'll ever be the same. Whew! Rich
              DrSprocket
                • 1676
                Mike, as far as I know Kent doesn't do e-mail. I'll look up his phone number and PM it to you...means you'll have to get up in the middle of the night to phone him!
