Oil lines
  • Scooterman7
    • Jun 2011
    • 5
    Oil lines
    Does anyone know the correct positions for the oil line connections to the tank?
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    USUALLY, on the OUTside. Hope this helps!
    (What are you talking about???)
    Gerry Lyons #607
    http://www.37ul.com/
    • Robin--M
      • May 2011
      • 23
      Scooterman,
      What year Scout? There's a big difference between the years.
      Robin Markey
      Bob's Indian Sales & Service
      • Scooterman7
        • Jun 2011
        • 5
        1940. The way they seem to fit best now is RF-return, LF-vent, LR-feed, RR-drain. Also, how does the wiring harness route between the tanks? I have it clipped to the bottom of the top frame tube. I can't find where it would exit out the back without interfering with the tank mounting. Does it go to the right or the left coming out the back?
