Does anyone know the correct positions for the oil line connections to the tank?
Oil lines
USUALLY, on the OUTside. Hope this helps!
(What are you talking about???)
1940. The way they seem to fit best now is RF-return, LF-vent, LR-feed, RR-drain. Also, how does the wiring harness route between the tanks? I have it clipped to the bottom of the top frame tube. I can't find where it would exit out the back without interfering with the tank mounting. Does it go to the right or the left coming out the back?
