Indian 4 cylinder
  • Indian 4 cylinder
    My friend has a 1934-1935 Indian 4 with a broken exhaust manifold flange. As you can see in the pictures he is working on a fix but would like to find a replacement if possible. If anyone has a cylinder with either a standard bore or maybe one that need re-sleeving please let me know. Thank you. Mark.
    why not braze the old cylinder? done correctly it would be as strong as the original flange
      I think that will be the way he will have to go. I just wanted to see if there was anyone on the forum who may have a replacement cylinder. Thank you.
        I have an extra motor, but I don't want to let it go just yet. Talk to Larry at All-Cast. He welded up my Indian 4 cases and cylinders. A top notch guy. He can do just about anything for you.
        http://www.allcast-inc.com/
          I am interested in the motor when you let it go. Have everything else for 28-31 but motor. Very interested. PM me if you decide to sell please.
            Might send Bud Redmond, Sunflower Chapter Wichita, a picture, he does cast iron welding....very old school correct
              http://www.ebay.com/itm/262451539788...%3AMEBIDX%3AIT
              New eBay listing
                The cylinders look the same, but there is a difference in the exhaust ports form 1930 to 1933 Banjomike
                  I think that looks like an easy fix for good cast iron welder ....and I also know that 32 is different from 34. Jerry
