My friend has a 1934-1935 Indian 4 with a broken exhaust manifold flange. As you can see in the pictures he is working on a fix but would like to find a replacement if possible. If anyone has a cylinder with either a standard bore or maybe one that need re-sleeving please let me know. Thank you. Mark.
Indian 4 cylinder
Tags: None
I think that will be the way he will have to go. I just wanted to see if there was anyone on the forum who may have a replacement cylinder. Thank you.
I have an extra motor, but I don't want to let it go just yet. Talk to Larry at All-Cast. He welded up my Indian 4 cases and cylinders. A top notch guy. He can do just about anything for you.
I think that looks like an easy fix for good cast iron welder ....and I also know that 32 is different from 34. JerryLast edited by Jerry Wieland; 05-28-2016, 09:20 AM.
