How to remove a clutch hub on a 1948 Chief
  • Igor
    • Apr 2026
    • 28
    Hey everyone,
    I’m trying to remove the clutch hub on my 1948 Chief and could use some advice.
    I’ve fabricated a homemade puller tool, using the clutch sprocket itself to pull the clutch hub off the shaft.
    tried it carefully just now but the hub is on there really tight and doesn’t want to budge.
    My questions:
    • Is this a good approach or could something break using this method?
    • Any tips or alternative ideas?
    All advice is welcome, thanks in advance!
    Igor
    This gallery has 2 photos.
  • otis71
    • Jul 2015
    • 590
    Try shocking it with tension on it.
    • FNG1
      • Oct 2014
      • 197
      How thick is your puller plate? It may just be deforming. Like otis71 said, a tap on the puller screw while its tight would help. Maybe add some stiffening to the plate. Hope this helps.
      • tfburke3
        • Oct 2011
        • 958
        Remove the puller plate.Use a small curved pry bar,like brake adjuster tool,pry the hub outward from basket, and tap shaft with hammer to break taper.Some heat may help but usually not necessary.
        • FLFD7
          • Feb 2021
          • 735
          Igor,
          I'm confused by your puller design, it looks like you are hoping that the clutch basket will knock the hub off the shaft taper? I think what's happening is your disc is pulling on the basket by pushing off the end of the main shaft with a center bolt? If that is what you are trying then it won't work cause the basket is secured with a nut in the transmission case, you tugging on the clutch basket screws will not pull the basket (or hub) outward, it'll just keep getting tighter, which is what you describe as happening.
          A little heat is your friend. And a smack on the hub opposite from the key.
          Joe
          • PaulCDF
            • Aug 2019
            • 1399
            Chief Primary Geers.jpg Diagram from Geers:
            And note: (More to myself than you) when we are talking about hammers and striking things rawhide, or lead (Pb) hammer or lacking either a block of wood between object and hammer.
