How to remove a clutch hub on a 1948 Chief
  • Skirted
    • Sep 2012
    • 709
    Hi Igor,
    If you are rebuilding the Autolite gen for 12 volt, make sure you convert the voltage regulator to electronic so you can use a sealed battery such as a Shorai. I know the desire to keep our old bikes looking as original as possible and I've done that to a fault at times. If you don't plan to have the bike AMCA judged, for example at the Raalte meet, an option to consider is simplfying life and the process and install a Cycle Electric generator with built in regulator and you're all set for a sealed battery and reliability.
    I am running the original Autolite converted from 3 brush to 2 brush on my 48 (6 Volt) with an electronic voltage regulator and its been 100% trouble free for many thousands of miles. The 38 Chief had a Cycle Electric on it when acquired and at first I was considering changing it to an Autolite for authenticity appearance, but then wised up and decided to leave the high reliability unit in place as I will never have the bike judged!
    PS I bought my 48 (first real antique bike) when I was 50 over 14 years ago and plan to be kicking for a long time yet. You are good for many years my friend! These Indians start easy and reliably when setup properly.
    Jason Zerbini
    #21594
    • Igor
      • Apr 2026
      • 37
      Originally posted by Skirted View Post
      Hi Igor,
      Hi Jason,
      Thanks for the advice and for sharing your experience.
      I contacted Frank Vandevelde and he is actually building an original Autolite for me now, converted to 12V with an electronic regulator, so it sounds like I'm heading in the right direction.
      I want to keep the bike as close as possible to its original patina appearance, but I don't plan to have it AMCA judged. So in the end it will probably be a mix of original parts and some sensible upgrades for reliability and riding.
      And good to hear I should still have plenty of kickstarting years ahead of me!
      Thanks!
      Igor
      The Netherlands
      Igor – The Netherlands
      1948 Indian Chief
      Learning while wrenching​
      • Igor
        • Apr 2026
        • 37
        2-row clutch sprocket on 1948 Chief
        My original 85376 clutch sprocket was modified for an electric starter. One row was machined off, leaving 2 rows instead of the original 3.
        The starter is now removed. The engine sprocket and primary chain are still the standard 4-row type.
        I’ve been told the 2-row setup can be used without problems, but to check the primary chain carefully for broken rollers.
        Would you keep running this 2-row sprocket, or replace it with a standard 3-row 85376?
        Anyone have long-term experience with this modification?
        1948 Indian Chief
          • 968
          I would not consider running it,Sourcing a good part should be fairly easy and to me would be worth the peace of mind.
          • Igor
            • Apr 2026
            • 37
            Thanks Tom, I had my doubts about running it as well.
            I’ve now found a good original clutch basket on eBay, so I’ve decided to replace the modified one.
            Definitely worth it for the peace of mind.
            Thanks for your advice!
            1948 Indian Chief
            • PaulCDF
              • Aug 2019
              • 1431
              IMO your original clutch sprocket with the missing row of teeth will make a fine start for some garage art (Perhaps a trouble light base) so all is not lost.
              • Igor
                • Apr 2026
                • 37
                Haha, good idea Paul! I’ll keep it together with all the other modified electric starter parts. Maybe one day I can build a complete lamp out of the whole system, at least then the electric starter will finally work for something.
                1948 Indian Chief
