Possable trouble with fuel / oil tank 1947 chief
  • slagcity
    • Jan 2022
    • 4
    Im in the last stages of assembling my 47 . Short story, the bike fell over onto the tank .(landed hard on a bike jack) . So the tank has oil in it as ive been running and riding the bike with fuel in the other side . I look into filler hole and see that there is a small coating of oil in the fuel tank . Not a lot . but , Im wondering what to do next , I think what Im going to do is
  • slagcity
    • Jan 2022
    • 4
    What im going to do is ,use fuel out of the left tank and leave it alone till I see measurable oil in fuel side. Any comments for a fix , ?
      • 968
      Sounds like you need to repair or replace right tank.If your getting oil in the left tank the right petcock must leak but I think gas would show in rt tank.If you are talking about oil leaking past divider into the right tank thats not uncommon.I run only the left side with fuel on my 47 just out of caution if the divider on right tank should start to leak
      To repair properly,if you can find someone ,would require taking apart,dent repair, stripping,tinning? and resoldering or brazing with hole locating jig ,and testing.
      SOme just cut a hole on the back and attempt to resolder,
      You could look for a good used tank.50-53 are brazed and would be my choice although not original with more rear taper and modification required for 47 dash.
      Or try Kiwis new welded tanks.Not sure if sold separately.
      You could try sealer in the gas tank but I would not.
      Interesting that in 1934 chiefs had 2panels to separate the gas and oil with an air gap in between so no possibility of gas getting in oil.They must have saved about 2 bucks with the new inferior design.
      • PaulCDF
        • Aug 2019
        • 1431
        Old soldered tanks?
        Or
        Welded Repo tanks?​
        Consider:
        Drain oil out of your Oil Tank.
        Fill Reserve Gas Tank with Gas.
        Mark level on a stick.
        Let sit 1-2 days.
        Oil tank SHOULD be dry
        IF NOT
        You may leak between oil and gas chambers.
        • slagcity
          • Jan 2022
          • 4
          I belive that they are soldered . Im going to start looking for a replacement . When I get one , fix the old one , and swap out . One thing for sure, I will just use the right tank for oil..
          Might be a good winter to learn tank repair .
          Woodrow
          • PaulCDF
            • Aug 2019
            • 1431
            AMCA magazine archives:
            Winter Issue, 1993 Vol. 32, #4
            Tech Tips pages 24-27
            Antique Motorcycle Gas Tank Repair,
            Part I by George L. Yarocki
            Spring Issue ,1994 Vol.33, #1,
            Tech Tips pages 22-25,
            Part II by George L. Yarocki
            For professional help:
            Alex Trepanier
            Harry’s Radiator shop since 1919. Los Angeles CA 626-592-2212
            This might be a fix that Caswell Epoxy coating would be a good application for
            • PRG
              • Nov 2006
              • 616
              Howdy sir,
              Oil in your gas an annoyance, vice versa, dilutes your oil and can wash down cylinders causing bore scuffing and possible seizure.
              Cheerio,
              Peter
              #6510
