Indian Chief
  • rlassiter
    • Feb 2024
    • 25
    Indian Chief
    Looking for some help on removing/installing girder fork springs without damaging surface finish. My 46 repair manual says to remove upper and lower seat nuts and pry spring out of lower seat first then pull out the upper section. Install in reverse order. Well that sounds easy right? There has to be some way to compress the spring and install without damaging the paint. Any help will be appreciated.
    • 1672
    Roger, it's been a while but I used a ratchet strap: https://forum.antiquemotorcycle.org/...end#post118213
    • rlassiter
      • Feb 2024
      • 25
      Thanks Harry, I will give it a try.
      • PaulCDF
        • Aug 2019
        • 1422
        "Looking for some help on removing/installing girder fork springs without damaging surface finish."
        Roger
        Check Kiwi Indian tech videos Mike has a couple on girders:
        kiwiindian.com/pages/tech-videos
