I am looking to find out if someone has a nipple removal tool they could post a picture of? also a rivet install tool, Thanks in advance
Chief nipple removal tool
On Harleys I never turn out the nipples. I cut them and then peel them out. You chance running threads by turning them out.Originally posted by RonH View PostI am looking to find out if someone has a nipple removal tool they could post a picture of? also a rivet install tool, Thanks in advance
Jerry
- 1 like
Agreeing with Jerry, the design is the same for Indians, Folks!Originally posted by Jerry Wieland View Post
Jerry
(Although they are more forgiving...)
If this link still works, anvil tooling for reinstallation is shown.
https://web.archive.org/web/20250615...hleaktest.html
Extra attention should be given to sealing the rivet, using a tapered head instead of a button head:
The taper seals into the nipple from the inside, pressed outward by the cam-action anvil, so a malleable rivet can easily barrel out on its shank for a seal, and "upset" to a slight mushroom outside to lock it.
Over-peening is the mark of an amateur; Please bubble-test again after any sealant has cured.
....CottenLast edited by T. Cotten; 02-06-2026, 10:02 PM.AMCA #776
Removal requires center-drilling the rivet, and punching it into the port, Ron,Originally posted by RonH View PostI am looking to find out if someone has a nipple removal tool they could post a picture of? ....
Can you locate both the head of the rivet on the inside, and the upset between fins on the outside?
Please observe the upset, as you will want to duplicate it for posterity,
.....CottenLast edited by T. Cotten; Yesterday, 06:36 PM.AMCA #776
- 1 like
