Chief nipple removal tool
  • RonH
    • Jan 2016
    • 213
    I am looking to find out if someone has a nipple removal tool they could post a picture of? also a rivet install tool, Thanks in advance
    • 2024
    On Harleys I never turn out the nipples. I cut them and then peel them out. You chance running threads by turning them out.
    Jerry
      Jerry
      Agreeing with Jerry, the design is the same for Indians, Folks!
      (Although they are more forgiving...)
      If this link still works, anvil tooling for reinstallation is shown.
      https://web.archive.org/web/20250615...hleaktest.html
      Extra attention should be given to sealing the rivet, using a tapered head instead of a button head:
      The taper seals into the nipple from the inside, pressed outward by the cam-action anvil, so a malleable rivet can easily barrel out on its shank for a seal, and "upset" to a slight mushroom outside to lock it.
      Over-peening is the mark of an amateur; Please bubble-test again after any sealant has cured.
      • RonH
        • Jan 2016
        • 213
        Thank you two for the answers!
          I am looking to find out if someone has a nipple removal tool they could post a picture of? ....
          Removal requires center-drilling the rivet, and punching it into the port, Ron,
          Can you locate both the head of the rivet on the inside, and the upset between fins on the outside?
          Please observe the upset, as you will want to duplicate it for posterity,
          .....Cotten
          • RonH
            • Jan 2016
            • 213
            Thank you, this will be good for future knowledge.
