Motolamp
  • Motolamp
    Motolamp's use the 3-hole twist and lock headlight bulb. Is there a specific name for the base of these type bulbs?
    Secondly, I have a Motolamp style bulb holder that mounts to the reflector. The two pins are 180 degrees different than my others. Were early Motolamp bulb holders different?
    P15D-30 is the base number, This one?
      I have a 1942 that looks very different in several ways. There could have been a change between '42 and '49-'53.
      However, I have only noticed the difference on the internal parts, not the bucket, bezel or glass.
      People once told me, the '49-'52 Indian Vertical bezel has different mounted screw fitting at the join.
      I don't know anything about the bulb base names.
      Can't locate my photo right now. If you need a comparison, I'll see if I can post tomorrow.
      -JR
        ...this is from https://www.classicandvintagebulbs.com , a really good online source for bulbs :
          The early Motolamps, say 1930-39 used a regular straight two pin bulb holder. Harley went to the three point fixing in 1935 with the change to the Cycleray headlamp, but I don't know the equivalent Indian date.
            I call them "Pre-focus" bulbs only because that is the term used by a seller I them from.
              I bought a box of 3 pin bulbs at Hersey and when installed the contacts are 90 degrees off from the original Cycleray socket. Never did find information on different ones.
                RestorationStuff.com
                Prefocus Socket
                Double Contact
                ELE056
                $20.00
                Sorry could not download photo
