Motolamp
  • motor-officer
    • Feb 2011
    • 199
    Motolamp
    Motolamp's use the 3-hole twist and lock headlight bulb. Is there a specific name for the base of these type bulbs?
    Secondly, I have a Motolamp style bulb holder that mounts to the reflector. The two pins are 180 degrees different than my others. Were early Motolamp bulb holders different?
  • RonH
    • Jan 2016
    • 213
    P15D-30 is the base number, This one?
    • JTR249
      • Jul 2019
      • 768
      I have a 1942 that looks very different in several ways. There could have been a change between '42 and '49-'53.
      However, I have only noticed the difference on the internal parts, not the bucket, bezel or glass.
      People once told me, the '49-'52 Indian Vertical bezel has different mounted screw fitting at the join.
      I don't know anything about the bulb base names.
      Can't locate my photo right now. If you need a comparison, I'll see if I can post tomorrow.
      -JR
        • 1676
        ...this is from https://www.classicandvintagebulbs.com , a really good online source for bulbs :
          The early Motolamps, say 1930-39 used a regular straight two pin bulb holder. Harley went to the three point fixing in 1935 with the change to the Cycleray headlamp, but I don't know the equivalent Indian date.
          • PaulCDF
            • Aug 2019
            • 1431
            I call them "Pre-focus" bulbs only because that is the term used by a seller I them from.
            • otis71
              • Jul 2015
              • 597
              I bought a box of 3 pin bulbs at Hersey and when installed the contacts are 90 degrees off from the original Cycleray socket. Never did find information on different ones.
              • PaulCDF
                • Aug 2019
                • 1431
                RestorationStuff.com
                Prefocus Socket
                Double Contact
                ELE056
                $20.00
                Sorry could not download photo
                • RonH
                  • Jan 2016
                  • 213
                  I have a few of those, I'll be in Daytona at the AMCA meet at the stadium.
