Indian Sidestand
  • motor-officer
    • Feb 2011
    • 199
    Indian Sidestand
    Can anybody tell me the specific differences between the 1948 style sidestand and the 1950-53 style sidestands?
    Also, I have seen a few of these with a threaded "J" bolt that wraps around the frame and comes up thru the mount. When was this style used?
  • PaulCDF
    • Aug 2019
    • 1431
    ​ "specific differences between the 1948 style sidestand and the 1950-53 style sidestands?"
    All I got from Hatfields:
    Grrrrrrrrrr Did not upload on first post.
    • tomfiii
      • Jun 2007
      • 314
      Per service shot 190 it gave directions how to add J bolt for early '48 bikes.
        • 968
        I have the a 48 style on my 47 and also have a 51.
        My stands look identical.I don't know about j bolt.
        I recall some posts about the difference being the mount pad for the leg having a slightly different angle on the flat and hole with same leg.
        • RonH
          • Jan 2016
          • 213
          Tom, That is exactly what Todd at Greers told me, the mount pad is just a little different.
          • PaulCDF
            • Aug 2019
            • 1431
            "Number 190
            February 23 , 1948
            The jiffy stand bracket may be reinforced to prevent breakage
            by anchoring it to the frame lower tube by means of a "J"
            shaped 3/8" bolt, nut and plain washer.
            The brackets must be drilled for the "J" bolt (.386 diameter
            drill) as shown on the sketch below:
            Write in to the Indian Service Department for the number of
            J bolts, nuts and washers you need for installation on
            the early 348 models which did not have the jiffy stand bracket
            reinforcement.
            These parts will be shipped to you no charge."
