1935 chief
  • hairynob24
    • Feb 2011
    • 347
    1935 chief
    G day everyone, I have a question on how can I determine if the cast iron heads are high or low compression without pulling the motor apart, this is a running bike , person who did the top end is no longer with us . Another problem with the bike it has scout fork legs not chief so the bellcranks are pointing at 1 clock has anyone got a contact for these, cheers Rob
  • bstevens479
    • Jun 2011
    • 109
    My understanding is that cast iron heads 32-35 were standard compression & aluminum heads were for the Y motor, I don't know of a 3rd option.
      • 965
      Hatfields Resto guide 1935 std.comp. 74715 rear,74714 front
      optional low compression 74717 rear,74716 front
      I don't believe they are marked, low comp. may have noticeable bigger gap between head and cylinder,and I think cast iron pistons.
      • hairynob24
        • Feb 2011
        • 347
        Thanks for your reply guy's, the parts manual has low n high compression heads in case iron, as well as aluminium head for the Y motor. I found a repo set of fork links through IPE very nice parts, cheers Rob
