Generator Pulley
  • PaulCDF
    • Aug 2019
    • 1423
    Generator Pulley
    I am changing generators. My drive pulley has been notched/flattened to ease belt replacement.
    QUESTION: What is the ideal position of the "flat" to accomplish this?
    • 965
    Because there is very little clearance between the pulley and the trans top the flat allows the belt to be removed when it is rotated to the bottom.
    It is so easy to remove the pulley I would not do this but apparently some think its an improvement.
    • PaulCDF
      • Aug 2019
      • 1423
      Thanks Tom!
      • bstevens479
        • Jun 2011
        • 109
        I agree with Tom, how often do we change belts.
        • DEEBS47Chief1991
          Living The Dream
          • Jan 2023
          • 1256
          I keep a very thin coat of grease on the pully shaft and key. The nut has blue Loctite. The pulley comes off easily when its needed. Indian Frank just rebuilt mine to 12V specs so I will be doing this job soon as well.
          • PaulCDF
            • Aug 2019
            • 1423
            Thanks All
            Indian Frank rebuilt mine as well replacing the Cycle-electric unit,
