Pushrod Guide Installation
  • icenaxes
    • Nov 2024
    • 6
    Greetings all! I found a helpful topic started by CSCOTT in 2009 on how to remove Pushrod Guides. I'm ready to install my new Pushrod Guides into my 48 Chief. Any suggestions on the best method to press them in? Due to the insertion angles on the crankcase, it looks like I might need a jig.
  • PaulCDF
    • Aug 2019
    • 1423
    Okay Ice best I could find on topic is from VirtualIndian group [https://groups.io/g/VirtualIndian]
    (Are you there?)
    This from Mike Tomas of Kiwi Indian 11/14/2009
    "Check interference fit before installation.
    Preheat case in an oven to 250 deg.
    Pushrod guides are pressed in using Loctite product for sealing. While
    the case bore has a very fine micro finish as well as the pushrod guide,
    the Loctite is merely used as an insurance policy should any oil want to
    try and migrate upwards.
    Cases are then allowed to cool slowly.
    Whether they be original cases or our Kiwi reproduction cases (and
    original and Kiwi pushrod guides), the interference fit is the same."
    "I am going off memory (as my prints are stored off site) but I believe the push rod guides are a 0015 to .002 interference fit."
    Original post is longer but that is the gist of it.
    There are other valve guide related posts there worth a look.
    • DEEBS47Chief1991
      Living The Dream
      • Jan 2023
      • 1256
      And the Loctite to use is the green 603 retaining compound. Not red or blue thread locker.
      • icenaxes
        • Nov 2024
        • 6
        Epic! Thank you both! The install notes and Locktite reference saved me hours of guessing. Now it's time to heat up the oven and go to the parts store for 603! I'll keep ya posted.
        • PaulCDF
          • Aug 2019
          • 1423
          "hours of guessing"
          Ice;
          I need to ask are your guides badly damaged or worn beyond fitment of oversized pushrods???
          • DEEBS47Chief1991
            Living The Dream
            • Jan 2023
            • 1256
            • icenaxes
              • Nov 2024
              • 6
              It's assembled and ready for another 70+ years. I'll post pictures of my motor rebuild soon. Thanks all!
              • PaulCDF
                • Aug 2019
                • 1423
                How did pushrod guide installation go?
