Numbers Expert
    • 8234
    Originally posted by DEEBS47Chief1991 View Post
    Indian did use Amal on the 52 and 53 Chiefs. Most people chucked them and installed the Linkert.....
    Never has an Amal manifold crossed my benches, Folks...
    So I suspect they are rarer than the carbs!
      • 965
      Indian did use Amal on the 52 and 53 Chiefs. Most people chucked them and installed the Linkert. I had them on my BSAs. Metal on metal slides are pure air leaking junk. However, you can still buy a repop replacement if you choose to go for the 100 points.
      No listing for the MBONN ?
        • 8234
        It seems the Bonneville designation went away for M350 and M352, Tom,..
        Because all internals were Bonne equivalent anyway.
        I have never recorded an M351!
        PS: Until fossil record proof is presented, I doubt any M346, M347, or M442 as well.
        Frankly, the M542 and M648 listings are suspect.
        We must ignore omissions, like the M741-1?
          • 965
          If 1940 and earlier chiefs were Scheblers,was the MBONN ever listed for 46-48 which I think are the most likely years.
          • Skirted
            • Sep 2012
            • 706
            Originally posted by JTR249 View Post
            Cotten,
            Correct. The 49-52 verticals ran the Amal 275 on Arrow and scout, the Amal 276 on both Warrior models.
            I don't think the '49 Chiefs, even if they were put together with left-over '48 parts, ever used Amals.
            That would be very strange indeed.
            -JR
            The 49 Arrow and Scout had Linkert S2 or S3 carbs. At least some of them. Pictured is an S3
            Jason Zerbini
            #21594
              • 8234
              It ain't easy, Tom,...
              When the pre-Linkert '40 Indian parts book lists Bonnes that may never have existed.
              PS: I trust a well established Indian authority that there were no Bonne Schebs.
              • DEEBS47Chief1991
                Living The Dream
                • Jan 2023
                • 1256
                Tom, I dug up some info on the manifold. It looks like they used the Indian Manifold with an adapter similar to the unit used for Keihin CV carb adapters.
                • DEEBS47Chief1991
                  Living The Dream
                  • Jan 2023
                  • 1256
                  You can still get one. Wow.
                    • 8234
                    Looks a lot smarter than the Keihin, Deebs!
                    No rubber to eat.
                    • DEEBS47Chief1991
                      Living The Dream
                      • Jan 2023
                      • 1256
                        • 965
                        I had a similar adapter on my first Indian 80cu with a Volvo SU H6 1 1/2" .Constant velocity,a great carb for a chief except it stuck out a little.
                        I think a much better design than the Amals,but a little big on motorcycle.
                        No rubber either.
                        • DEEBS47Chief1991
                          Living The Dream
                          • Jan 2023
                          • 1256
                          #27
                          That sounds cool. Like this?
                            • 8234
                            #28
                            Looks like an another evolutionary dead end to me, Folks!
                            (Like the 'modern' HD Tillys, which go down in History with Lectrons, Lake Injectors, etcetera.)
                            The DLX design ruled from about '12 through '65, truly the Golden Age of American motorcycling.
                            Yet just a half-century later, we have no valid explanation how the Linkert idle bleed slot was cut, as if it were the Egyptian Pyramids.
                            PS: Over a decade ago, I held a modern-cast EDM attempt in my hands, and outfitted it to run, with hardware.
                            The slot looked *marginal*, I guess.
                            And the *entrepreneur* stiffed me totally, so we shall never know how it ran.
                            No good deed,...
                              • 965
                              #29
                              Yes but a little different float bowl connection.
                              Currently have a pair of 1 3/4" on 1959 Triumph TR3.
                              • FLFD7
                                • Feb 2021
                                • 736
                                #30
                                Here is the Amal (original) off my 53 Chief….
                                In addition to the manifold adaptor there is a threaded flange and a spacer for mounting the air filter.
                                This carb hasn’t been on the bike for over 40 years, it has a M352 and runs great. I still have the Amal handlebar controls….
                                My father always claimed he had a 49 Chief engine out of a NYC cop bike. I haven’t come across it yet in his stash, but when I do I’ll be sure to post some pictures of the numbers.
