I suppose it's gasses getting past the rings that cause the low mileage to turn oil black or dirty looking. Hmmm. Anyway; after draining the motor oil; what is the best fluid to use to flush out the tank?
Clean Out The Oil Bucket?
Diesel is cheapest, John!Originally posted by John Guntner View PostI suppose it's gasses getting past the rings that cause the low mileage to turn oil black or dirty looking. Hmmm. Anyway; after draining the motor oil; what is the best fluid to use to flush out the tank?
And most convenient as well.
....CottenAMCA #776
- 4 likes
I understand why you would want to swab out any crap you can, Deebs!Originally posted by DEEBS47Chief1991 View Post2nd vote for diesel. Wipe it out good after to dry it.
But what point would it be to get it dry?
Thanks in advance,
....CottenAMCA #776
So there is no chance of watering down the lubrication (no matter how slight). I like using diesel like you suggested because of the low flash point.
- 1 like
Seriously Deebs,...Originally posted by DEEBS47Chief1991 View PostSo there is no chance of watering down the lubrication (no matter how slight). I like using diesel like you suggested because of the low flash point....
Obviously there are more safety concerns with gasoline than diesel.
Unless you are a smoker, I wouldn't even worry much about a little gas.
Dad said they thinned motor oil with kerosene for Nebraska winters, and that's close enough to #2 diesel.
I do like riding in the winter Tom. But I would not thin my oil in such a way. I guess that's all they had back then when top ends lasted 10,000 miles.
The coldest I rode, Deebs,...
Was a few miles at ten below to get to work.
Put the oil in a coffee can on the stove pilot light overnight (remember those?), poured it direct into the Honda 450, and the only problem was visibility with a face shield.
Miss my Honda most of all...
....CottenLast edited by T. Cotten; 08-05-2024, 04:32 PM.AMCA #776
Honda 450. Cool bike. Was it a Black Bomber like this? Or a little newer like this red 70?
