Clean Out The Oil Bucket?
  • John Guntner
    • Feb 2007
    • 192
    I suppose it's gasses getting past the rings that cause the low mileage to turn oil black or dirty looking. Hmmm. Anyway; after draining the motor oil; what is the best fluid to use to flush out the tank?
    Diesel is cheapest, John!
    And most convenient as well.
    • DEEBS47Chief1991
      Living The Dream
      • Jan 2023
      • 1256
      2nd vote for diesel. Wipe it out good after to dry it.
        I understand why you would want to swab out any crap you can, Deebs!
        But what point would it be to get it dry?
        Thanks in advance,
        • DEEBS47Chief1991
          Living The Dream
          • Jan 2023
          • 1256
          So there is no chance of watering down the lubrication (no matter how slight). I like using diesel like you suggested because of the low flash point.
            So there is no chance of watering down the lubrication (no matter how slight). I like using diesel like you suggested because of the low flash point....
            Seriously Deebs,...
            Obviously there are more safety concerns with gasoline than diesel.
            Unless you are a smoker, I wouldn't even worry much about a little gas.
            Dad said they thinned motor oil with kerosene for Nebraska winters, and that's close enough to #2 diesel.
            • DEEBS47Chief1991
              Living The Dream
              • Jan 2023
              • 1256
              I do like riding in the winter Tom. But I would not thin my oil in such a way. I guess that's all they had back then when top ends lasted 10,000 miles.
                The coldest I rode, Deebs,...
                Was a few miles at ten below to get to work.
                Put the oil in a coffee can on the stove pilot light overnight (remember those?), poured it direct into the Honda 450, and the only problem was visibility with a face shield.
                Miss my Honda most of all...
                • DEEBS47Chief1991
                  Living The Dream
                  • Jan 2023
                  • 1256
                  Honda 450. Cool bike. Was it a Black Bomber like this? Or a little newer like this red 70?
