I picked up what I believe to be a NOS case half, or maybe it’s slightly used. In any event, are these year specific?
Left Hand Crankcase
Here it isYou do not have permission to view this gallery.
This gallery has 2 photos.
- 1 like
1938 had breather hole,not sure about 1939.1944 had timing hole so probably a 1940-43Originally posted by exeric View PostI see the breather boss isn't drilled, and tapped. I believe 1936 was the last year that boss was D&T'd for a breather elbow. Regardless, Joe, that is a great find.
Now the question.Do you number it with correct stamps just like every dealer or later restorers would back in the day or use it as is blank.
Is a boss stamped for the first time really altered?obviously not same as factory numbered,but not a file off and restamp either.
Any non-factory stamping, Tom,...Originally posted by tfburke3 View Post....Do you number it with correct stamps just like every dealer or later restorers would back in the day or use it as is blank....
Is a felony in most states (or used to be...)
(Unless the State does it, and that's always worse.)
PS: The Illinois State Police Inspector explained it to me that it would be theft against Indian® to produce a unique machine in its name,.. and fraud, of course, to alter and present to due process a booger.
If you wanted to stamp the cases just for fun you could use the correct tool to do it.
https://www.ebay.com/itm/174187706829
