Vacuum grip pliers
    • 959
    Vacuum grip pliers
    I have Vacuum Grip brand pliers sold by starklite and others as Indian valve cover pliers.
    The teeth are closer together than the Indian covers and tear up the covers.
    What did Indian sell for this purpose?
    Anybody sell a tool that fits?
    • 8229
    Gosh, Tom,..
    I'll admit I wore heavily upon my KIWI Vacuum-Grips, but although 'soft', they seemed to fit.
    The majority of wear was from brand x fuel filters, which they also fit quite well:
    My superior Michael Breeding pair is virgin. (Offers accepted.)
      • 959
      If you look at how they fit on a chief cover you see the difference.Looks like they fit the Harley parts right.
      Curious what Indian sold or what fits.I just don't think Indian would sell a tool with wrong profile that tears up a cadmium cover pretty quick.
        • 8229
        I assure you Tom,
        I used the KIWIs on multiple Chiefs without issue!
        (...Other than wear upon the pliers, rather than upon the covers, which could be considered an advantage.)
        I better check my walls and inventory, because there might be three Vacuum-Grips around here. That would make me a collector.
        .....Cotten
          • 1664
          It would be interesting to see if the reproduction pliers fit original covers correctly, because maybe it's the reproduction covers that have a different pitch?
            • 959
            Thanks for your assurance Tom.
            I have also used them for many years.
            I guess I should have just asked"what did Indian sell for valve cover removal"
            Were they just reselling the Vacuum grip,or was there an Indian tool.
            BTW,I never had repro covers but I believe the available copies are the same related my question.
            • PaulCDF
              • Aug 2019
              • 1404
              "was there an Indian tool." (?)
              From the AMCA Library
              ARMY MOTOR MAINTENANCE
              Text No.9
              The Motorcycle
              Sept 30, 1940
              Pg 42
              "For the Indian Motorcycle (1) For the First Echelon. The tools supplied in the tool roll should be considered sufficient.
              (2) For the Second Echelon, there are only four additional motorcycle tools suggested namely:
              Wrench cylinder head 5/8" special length 11" Factory Part #: 101472
              Wrench socket cylinder head bolt, special extension, 5/8" Part #: 102312
              Pliers "Vaccum Grip Type", for valve covers Part #: 101826
              Wrench, box socket, special for headlight adjustment Part #: 102347"
                • 8229
                It doesn't take much time web-searching, Folks,...
                To figure out that 'Vacuum-Grip' was proprietary to 'Snap-On', with many other designs.
                My jewel Breeding pair has "Indian" upon the grips.
                (I'd take a pic but I hid them from myself.)
                  • 959
                  Text No.9
                  The Motorcycle
                  Sept 30, 1940
                  Pg 42
                  Thanks Paul.So Indian did not manufacture a special valve cover tool but distributed the "vacuum grip"pliers.
                  • PaulCDF
                    • Aug 2019
                    • 1404
                    Michael Breeding has a nice original one for sale:
                    "VACUUM GRIP VALVE COVER PLIERS with BOX, original, - 101826 - $175.
                    New Old Stock Pliers for Indians. These are the later version and fit covers with seals.
                    Donut type circles on the handle are the "vacuum grip" part. "Made in USA" on inner handle."
                      • 4773
                      Most motorcycle manufacturers bought tools from tool makers rather than make their own. An example here from "Indian" actually made by Vlchek. DCP_2783.JPG DCP_2784.JPG
                        • 959
                        Thanks for all the replies and pics
                        • PaulCDF
                          • Aug 2019
                          • 1404
                          So what I am wondering is:
                          Michael Breeding states "These (Part #: 101826) are the later version and fit covers with seals."
                          Was there a differant version for EARLY Covers without seals?
                          Could this be what Tom Burke has???
                            • 959
                            I believe later most likely referred to 40-53 sealed covers.
                            The military info you posted is 1940 which I believe is first year for sealed covers.
                            !939 was similar but no seals and these pliers could still be used.
                            !935-38 was split clam shell covers so no wrench needed.
                            !934 was a smaller diameter cover with hex flats to turn on or off.
                            "fits" is somewhat subjective I think.Yes they work.Would Indian have designed a tool with a better matching tooth profile?I think so.
                            Thanks again for all the replies
                              • 1664
                              I purchased a set from Starklite (I think) and they came in a period box, not for one second did I think I had scored an original set in the box, but it's nice they reproduced them with a period box:
                              Note how one end broke off short on one of the gripper jaws, I actually find it works better that way! Low clearance between the cylinder and the covers means the pliers have a difficult time fitting behind the covers, the shortened jaw gives me increased throw on the pliers with no noticeable loss of grip. Your mileage may vary!
