Brake Pad Question - '32 Chief
  • bdawson
    • Mar 2023
    • 124
    Happy Holidays everyone. I am in the middle of restoring the rear wheel and I am looking to replace the brake pad/lining on each brake shoe. Does anyone know who sells them, as I can't seem to find them anywhere? They are 1.4 to 1.5 inches wide....and they are quite a bit wider than the fronts. I can find the rivets and I can find front brake pads....just no rears. Greer appears to sell the entire brake shoe for $90 for a '36 chief, but I don't need the shoes, just the pads/linings. Any help would be appreciated. Thanks, Brent.
  • PaulCDF
    • Aug 2019
    • 1415
    Three thoughts:
    1. Ask Todd at Geers if they have/sell linings seperately
    2. vintagebrake.com
    3. McMaster-Carr.
    Hope this helps. Good Luck. Let me know what works out.
    • indian301
      • Jun 2010
      • 125
      Call Bob's Indian in Etters ,Pa. Ask for Robin
      • tomfiii
        • Jun 2007
        • 314
        • RonH
          • Jan 2016
          • 213
          I might have a set of pads here. PM me
          • otis71
            • Jul 2015
            • 594
            Another option is an industrial relining company. They have many different linings of varying hardness they can custom cut and bond. I had good luck with that option on my JD external band brake but unfortunately that local shop has since closed.
            • otis71
              • Jul 2015
              • 594
              Also if you give them the drum they’ll arch them to fit unlike most off the shelf.
              • bdawson
                • Mar 2023
                • 124
                Thanks for everyone's responses, I appreciate it. Ron....I sent you a PM. If you don't end up having any, I will pursue all of the other options here.
