Front fender running light
  • Front fender running light
    Hello, I'm in the later stages of re-assembling my '48 Chief. Can someone tell me what is the correct routing of the wire for the front fender running light? Should it be included in the woven headlight conduit, or does it go from the switch (as a single wire) to the terminal holder on the headlight mount.
    thanx,
    Wire goes directly to ignition switch. Believe wiring diagram shows that. Pics of how mine is from where it exits fender and up. Not say'in its 100% correct.
    Jason Zerbini
    #21594
      I suggest taking a look at Jerry Greer's site and the pictures they've posted of the restoration process for a '48 Chief. Here's one such picture:
      I also found that wire routing is hardly documented anywhere for Indians, I went to several meets and shows and snooped around other Chiefs and found that most, if not all, girder fork Chiefs used the same small connector for the fender lamp that Greer's shows on the lower cross member of the fork, here's mine:
      .. and here's what I determined "could be" correct for wiring from the fork to the dash:
      As I say, I only base this on what I've seen on other Chiefs, and Greer's is extremely reliable on restoring Chiefs to original...so that's what I went with!
        Thanks for correction Harry. That sure looks original to me. I did not know they had such detailed photos like that.
        Jason Zerbini
        #21594
          Hello, thanx pisten-bully and skirted for your responses, I was not aware of the restoration images on Greer's website. The images show two examples that are slightly different in themselves(one in woven conduit and one is just a wire). And they both differ from the method seen in the image provided by pisten-bully. To reiterate, my question is what is the routing of the front fender running light wire from the ignition switch to the terminal on the headlight support bracket.
          thank you again,
            ...here's three different Chiefs I took pictures of 10+ years ago. If you find a source showing the factory method of running that wire, please let us know...I never was able to find that!
              ...and this one is an OP Chief:
              ...and another I took 10+ years ago :
                Thanx for the images pisten-bully, it's a small detail and I'm not going to lose any sleep over it. I think I'm just going to wing it, and do what makes me happy.
                tom
                  Tom, from what I've seen, just put the wires in asphalt loom and run them over the lower triple tree between the shock and the left spring. If it's not correct then at least you'll be in good company!
                    Okay here's a few pictures of what I did:
                    And a picture of a 1950 Chief I snagged from Parkers Indians Australia ("Idea" photos not reference):
                    And finally a 1946 from recent auction (Looks like something I would do):
                    Good Luck!
                      Pisten-bully and skirted, thanx again for your help.
                      tom
                        something a little .. .. . different
                          Originally posted by blacknight55 View Post
                          I've seen a few of those over the years. Automotive accessory.
                          https://www.ebay.com/itm/37451706497...p2047675.l2557
