rear brake drums chief
  • cscott
    • Oct 2002
    • 451
    have these two rear brake drums, when disassembled the bearings popped right out is this normal or should they be pressed in? thanks chris
  • PaulCDF
    • Aug 2019
    • 1431
    Chris;
    1946 has a "bearing nut"
    Parts, restoration and engine work for 1936–1953 Indian motorcycles, from our shop in Deadwood, South Dakota. Search by part number or browse the diagrams for your model and year.
      • 1676
      my drum bearings don't fall out, but they aren't really pressed in either...a few taps on a block of wood with an 8oz hammer is enough for either an install or disassembly.
      • cscott
        • Oct 2002
        • 451
        thanks for the input, my bearing does fall out ithink i will wrap it with a layer of sheet stock, unless someone thinks this is a bad idea? thanks chris
        • RonH
          • Jan 2016
          • 213
          What is the numbers for the bearing in that hub? Thanks
            • 968
            5205 is the rear drum bearing.
            • DEEBS47Chief1991
              Living The Dream
              • Jan 2023
              • 1256
              If I am not mistaken, there is a small set screw that retains the bearing. You could make a small notch on the outside race for the set screw to sit in. Years ago I had mine loosen up and the bearing spun inside and ruined the hub. Mike at Kiwi advised me to install the bearing with Locktite bearing retainer (green) 609. It has been good ever since (early 90's repair).
              This gallery has 1 photos.
