12 volt agm battery
  • cwilli
    • Mar 2014
    • 9
    12 volt agm battery
    What brand and part number 12 volt agm battery do you guys run in a Kiwi battery shell? Or what are the inside dimensions of the shell?
    Thanks!
  • PaulCDF
    • Aug 2019
    • 1423
    Here is a link to a recent discussion of 12 volt batteries on this forum:
    chief 12v battery recommedation - AMCA Forum (antiquemotorcycle.org)
    I don't know the internal dimensions of the Kiwi battery shell, I got mine from Ziggy, I am sure Mike Tomas could give you the dimensions and most likely would also have a battery that would fit.
    My shell measures: 5-3/4" x 3" x 6"
    I believe Starklite also sells shells as well as shell & battery kits.
    If considering a Lithium Ion battery. The Lithium Ion battery option carries the following CAUTION: "This battery must be used with an electronic regulator or a new Cycle Electric Generator. IT WILL NOT WORK WITH AN ORIGINAL CHARGING SYSTEM! The original stock mechanical Cutouts and Regulators will overcharge the battery within 30 miles and cause it to catch fire."
      • 965
      check out deka.Made in pa ,they also make harleydavidison's batteries.
      Cheapest price was to order online from lowes.Took 5 days to pickup at my local store with a manufacture date 2 days earlier..
      I got the largest that would fit in a Starklite shell etx14.Most group 14 powersport batteries are about the same size.
      • cwilli
        • Mar 2014
        • 9
        Thanks. Who is Ziggy?
        • Skirted
          • Sep 2012
          • 707
          Jason Zerbini
          #21594
            • 965
            The nicest battery boxes I have seen are from'the battery box guy" chris daniels 704 236 5410 cdaniel677@ aol.com
            They are year correct not one size fits all.
            The Starklite is really a cover with no bottom and doennt like the frog bolt to tight.It works but my next one for 38 will be from Chris.
            • Architect
              • Dec 2014
              • 283
              I use an Anti Gravity lithium battery, I recommend buying from this vendor, good people that ride:
              https://www.dkcustomproducts.com/
              The battery is much smaller than the available space provided in the battery box. The lithium came with really nice foam padding, I cut as needed to make a snug fit. You need lithium specific battery tender and charger, only down side. Upside is I bought the charger 3 years ago and I have never needed to use it. Technology and all of that.
              • PaulCDF
                • Aug 2019
                • 1423
                Interesting; which Anti Gravity Lithium fits your shell? Must be an issue with their site when I went to Lithium Ion Batteries the only item that came us was self fusing tape. Have to try again later thanks for the tip.
                • Architect
                  • Dec 2014
                  • 283
                  This is the one I have on my 45, fits inside the battery box no issues. I could not find receipt to find out whose battery box I have, but pretty sure Battery Box Guy. battery was recommended for kick only motorcycle in my CC range.
                  • PRG
                    • Nov 2006
                    • 612
                    Howdy chaps,
                    Lithium batteries combining the best characteristics for our app are LIFePO4. One thing to note, these are starter not storage batteries like traditional LA or even AGM’s. Because of internal efficiency and construction they bring more amps to the starting phase and can achieve more depth of discharge (DOD) in the process without damage. Therefore it is not apple to apple comparison on amp hour (Ah) ratings with traditional storage batteries so they use a PB Ah equivalent formula. A typical Shorai BS 06 lists a Pb Ah rating of 18 A in the side data panel, flip it over and on the bottom and it lists only 6.0 Ah at 6.6V using traditional measurement.
                    Lithiums assume use of modern alternators which duty cycle at lower rpm and higher outputs than our old generators. 32E’s come “more alive”, shall we say, than Autolites or Millers when converted to two brush so the following not as much an issue. But, whenever I have - or can make with grinding of the case - the room, I try to fit two batteries wired in parallel for a little more reserve as performed on 8 of 9 of my machines running this setup.
                    Cheerio,
                    Peter
                    #6510
                    • PaulCDF
                      • Aug 2019
                      • 1423
                      Peter;
                      I like your idea of running two Shorai in parallel; I read and re-read your Nov 2006 post on this
                      but I got confused (Not hard to do). I run 12 volt with Cycle Electrics.
                      My question:
                      In your 2006 post you mention running two Shorai BS06's for 6 volt application on your Indian and
                      on your R69S BMW you run the 12 volt version. To be clear on the BMW you are using Shorai BS12's?
                      Thanks.
                      • PRG
                        • Nov 2006
                        • 612
                        Howdy sir,
                        This is the 1 out of the 9 not running paired batteries, rather, 1 Shorai BS12v on the lovely BTH 100 watt conversion that can be viewed at my link below. Besides having no room for two batteries, I essentially need a battery only as a charging system capacitor as it’s load demands are nearly non existent with LED head and taillight and a magneto based CD ignition. I might mention I have had 4 more Shoria’s and their speciality charger on back order for 3 months now……supply chain issues, you know.
                        This now permits a side-by-side comparison. Old system on the left, new on the right. Of note, and familiar to Vespa-types - 2 components lower right. The silver domed piece contains the magnets and turns just like the flywheel on your scooter. On the right the coils split their output between the 12V alternator and primary voltge for feeding into the CD coils to create spark. The item uapper right is the electronic regulator which is mounted between the fuel tank compartments on the frame rails and the black item above the tool coils on upper left is the ECU for the ignition system.
                        Cheerio,
                        Peter
                        #6510
