Hello. I am new to the forum and new to owning Vintage Indians. I jumped in feet 1st. I just invested in a 1947 Chief Roadmaster Bonneville (BM) and a 46 Chief. I am starting the proses of figuring out what is original and what is reproduction. I am very lucky to have a friend that really knows vintage Indians. My question is how can you tell a original / correct front end on a 46 & 47? Any help would be great. Thank you.
46 and 47 Front forks
Welcome to the forum! Off the top of my head one difference I know is 46 has shorter link shackles. I believe 4" hole center to center. 47 and 48 shackles are 4-3/8" center to center. I know 48 utilized more grease fittings on the girder linkage assembly vs 46 but can't be specific on 47.
I'm sure someone else will chime in.Last edited by Skirted; 03-21-2022, 12:26 PM.Jason Zerbini
#21594
Here's the link to the book:Originally posted by pisten-bully View PostWelcome! If you don't already have one, pick up a copy of Jerry Hatfield's Indian Motorcycle Restoration Guide as it covers lots of details
https://www.jerrygreersengineering.com/p/book/13835Jim
AMCA #6520
Lyle, my '46 (mid 2000's number) had needle bearings in it, the links are proper '46.Originally posted by Lyle Manheimer View PostAn original 1947 Indian front end will have one year only roller ( needle) bearings in the link pivot points. They may have been replaced as this was not a good idea, too much wear on the links, the links were not hard enough.
I should have said link shafts were not hard enough and the needle bearings caused premature wear. In 1948 they went back to bushings. I have no pictures and it has been a while since I looked at mine but I am pretty sure the holes in the girder are the same size regardless of whether bearings or bushings were used. Most needle bearing front ends have been updated to bushings due to link shaft wear.
