37 Chief backfiring through exhaust
  • Joseph Mangelos
    • Oct 2019
    • 47
    I have a 37 Indian chief battery model with high-performance cylinders (CCE - BY) and it all the sudden started backfiring out of the exhaust what should I look into? Typically doesn’t that suggest the timing is off?
    Thank you
    • 8238
    My first suspicion, Joseph,..
    Would be that the exhaust system has leaks, as seasonally cold, dense air will cause "reports" when sucked in, expanding rapidly against the hot metal.
    There are other possibilities, of course!
    • Joseph Mangelos
      • Oct 2019
      • 47
      Exhaust seems okay, but I noticed the battery is almost dead 4.3 Volts, which is odd as it’s less then a year old.
        • 1675
        Originally posted by Joseph Mangelos View Post
        all the sudden started backfiring out of the exhaust what should I look into? Typically doesn't that suggest the timing is off?
        Does it only occur on deceleration, or is it more frequent?
          • 965
          Is compression ok?
          • Joseph Mangelos
            • Oct 2019
            • 47
            It happens even when cruising and I have not checked the compression.
            Thanks to everyone for the suggestion.
            • Greasy rider
              • Sep 2017
              • 27
              I think i would start with the ignition condenser. When you solve the problem, don't forget to let us know.
              tom
                • 2024
                Low battery voltage could sure enough cause it to back fire.
                • Joseph Mangelos
                  • Oct 2019
                  • 47
                  It was the battery, I took the 6volt out of my Knucklehead and put it in the Chief and it ran smooth as could be.
                  I can’t believe it was the battery, so I spent the rest of the day driving around hunting for a replacement battery with no luck, so I had my son order one off Amazon and it will be here tomorrow.
                  Thank you to everyone for all the help.
                  • Joseph Mangelos
                    • Oct 2019
                    • 47
                    Jerry you are correct, it was the battery.
                    Thank you
                    • Skirted
                      • Sep 2012
                      • 708
                      Be sure to check the charging system voltage now to be sure new battery don't die.
                      Jason Zerbini
                      #21594
                      • Joseph Mangelos
                        • Oct 2019
                        • 47
                        Thank you, I did and it’s fine, so now I’m enjoying the bike.
                        Thank you all for the help.
