Indian chief oil pump timing
  • hdhikaru
    • Feb 2010
    • 217
    Hi,
    I am working on the chief engine.. it dose not have timing hole so I just check 1 1/2 inch below top dead end of front cylinder on compression.
    then put the oil pump to set the timing slit 90 degree against the body line... then how about the plunger? any correct direction? or dose not matter?
    I just put the white dot to see direction of the hole of plunger... any suggestion would be appreciated. thanks Shin
    • 965
    put distibutor and cap in pump in and slide the pump on to align the wires straight to the frame in full advance position .If its off back the pump off a little and change the initial position of the dist.Then secure the pump screws
    If thats 1 1/2" ,that way too much.1/2 -5/8 is better starting point.
    The plunger position is irrelevant.
    BTW that pump is pre 48.
    • tomfiii
      • Jun 2007
      • 314
      Manual says 1/2" and it's an early pump style '48.
      • hdhikaru
        • Feb 2010
        • 217
        ok. thank you guys!
