Just had my 48 chief motor rebuilt ,any recommend oil that I should use during break in ? Thanks
1948 chief motor rebuild
Originally posted by kitabel View Post"W" does not mean weight.
"The "w" in motor oil stands for winter. The first number in the oil classification refers to a cold weather viscosity. The lower this number is, the less viscous your oil will be at low temperatures. For example, a 5W- motor oil will flow better at lower temperatures than a 15W- motor oil. "
Online search quote
"Teachable moment"
Well this just proves that for important things I can NOT rely on my memory
I was WRONG.
Took a look in the garage (kept one of the old oil containers)
Actually
PENNGRADE
High Performance Break-In Motor Oil
SAE 30
Contains high levels of Zinc and Phosphorus
But I was right about what I am running now, so there's that.
