1948 chief motor rebuild
  • jn1972
    • Oct 2013
    • 84
    Just had my 48 chief motor rebuilt ,any recommend oil that I should use during break in ? Thanks
  • PaulCDF
    • Aug 2019
    • 1431
    My builder supplied me with Brad Penn conventional 50W Break-in oil: 3 Qts.
    Changed that at 500 miles and have been using Valvoline VR1 conventional 50w high zinc
    since. Change often.
    • kitabel
      • Sep 2018
      • 471
      "W" does not mean weight.
      The Linkert Book
      • ryan
        • Mar 2017
        • 610
        You are correct, the "W"stands for winter.
        "The "w" in motor oil stands for winter. The first number in the oil classification refers to a cold weather viscosity. The lower this number is, the less viscous your oil will be at low temperatures. For example, a 5W- motor oil will flow better at lower temperatures than a 15W- motor oil. "
        Online search quote
        • PaulCDF
          • Aug 2019
          • 1431
          "Teachable moment"
          Well this just proves that for important things I can NOT rely on my memory
          I was WRONG.
          Took a look in the garage (kept one of the old oil containers)
          Actually
          PENNGRADE
          High Performance Break-In Motor Oil
          SAE 30
          Contains high levels of Zinc and Phosphorus
          But I was right about what I am running now, so there's that.
          • ryan
            • Mar 2017
            • 610
            I run 60w in my Shovelheads.
            • PanheadFred1
              • Dec 2019
              • 75
              Where did you have your motor rebuilt?
