I have a '48 Chief with 16" wheels and Coker whitewalls. The recommended pressure in the Owner's manual is 16 PSI front and 18 rear, which seems low to me. Obviously, tires are much different now than they were then. I called Coker and they told me the max pressure for these tires is 32 and the tubes are likely rated about the same. His recommendation was to increase pressure to 22-25, but he seemed unsure.
What pressures tire pressures do you run on your bike, especially with similar tires?
Thanks.
Thanks.
