1948 chief kick starter
  • jn1972
    • Oct 2013
    • 84
    My 48 chief Kickstarter is loose on the kicker stud ,does any one make an oversized stud for the kick starter end I know they make oversized into the frame.can I shim the Kickstarter with bronze shim stock,or any ideas how to repair I am trying to keep the bike original thanks Jerry
  • swall
    • Dec 2002
    • 159
    How badly is it worn? I just measured the diameter of a new pin I have and it is 0.871" on the kicker end. Might give you some direction on where to go with this.
      • 968
      Greer list the standard size .876 and has 10,20 and 30 oversize.
      I ave a nos shaft,in a nos 1935 frame and it measures .874.
      Curious if the new .871 is an India product.I have seen some inexpensive kickers but it seems a lot of this India repro stuff is a little off.
      Edit: oversize listed for frame end.You may need new kicker and pin.
      • swall
        • Dec 2002
        • 159
        My pin is from Greers.
        • Greasy rider
          • Sep 2017
          • 27
          Can you bore the kicker and put a bushing in it?
            • 968
              • 1676
              Related question here, the kicker shaft, or pin, is a press fit into the frame, so what is the recommended clearance of the pin diameter to the bore of the hole in the frame?
              • swall
                • Dec 2002
                • 159
                Between a third of a thousandth and half a thousandth for freshly machined perfectly round holes.
                  • 1676
                  Thanks Steve!
